Protomold logo
Plastic Injection Molding
Proto Labs provides quick-turn thermoplastic injection molding often used for prototyping, bridge tooling and short-run manufacturing up to 10,000+ parts. We use advanced aluminum alloy molds that allow us to eliminate the costly and time-consuming custom engineering that normally goes into the development of tooling. Proto Labs offer hundreds of engineering-grade resins that produce molded parts that are strong and can have excellent finishes.
Quick-turn injection molding uses the industry standard production process for parts, so it’s an excellent predictor of manufacturability when you move to large-scale production. At Proto Labs, we support an ever-increasing maximum part size and degree of complexity, and continue to introduce new materials that help designers and engineers make better products.
25 to 10,000+ parts
Shipped in 1 to 15 days
Molds start at $1,495
PROCESS
DESIGN GUIDELINES
Fundamentals of Molding
Design Guidelines
Size
The maximum part outline that can be molded is approximately 18.9 in. (480mm) by 29.6 in. (751mm) or roughly equivalent to 175 sq. in. (1,129 sq. cm.). A maximum part volume of approximately 59 cu. in. Depth up to 4 in. (101mm) from the parting line with 3 degrees of draft, or up to 8 in. (202mm) total if the parting line can pass through the middle of the part, inside and outside. Deeper parts are limited to a smaller outline.
Size
Protomold size
Draft
A taper applied to the faces of the part that prevent them from being parallel to the motion of the mold opening is called draft. This keeps the part from being damaged due to scraping as the part is ejected out of the mold. Recommended draft:
  • 0.5 degrees on all vertical faces is strongly advised.
  • 2 degrees works very well in most situations.
  • 3 degrees is minimum for a shutoff (metal sliding on metal).
  • 3 degrees is required for light texture (PM-T1).
  • 5 or more degrees is required for heavy texture (PM-T2).
Draft
Protomold undrafted
Undrafted
Protomold drafted
Drafted
Protomold undrafted
Undrafted
Protomold drafted
Drafted
Tolerances
Typically, Proto Labs can maintain a machining tolerance of ±.003 in. (0.08mm) with an included resin tolerance that can be greater than but no less than ±.002 in./in. (0.002mm/mm).
Wall thickness
With injection-molded parts, observing proper (and uniform) wall thickness helps parts avoid potential issues such as sink marks and warpage. Recommended thicknesses vary by material:
Resin
Inches
ABS
0.045 - 0.140
Acetal
0.030 - 0.120
Acrylic
0.025 - 0.500
Liquid crystal polymer
0.030 - 0.120
Long-fiber reinforced plastics
0.075 - 1.000
Nylon
0.030 - 0.115
Polycarbonate
0.040 - 0.150
Polyester
0.025 - 0.125
Polyethylene
0.030 - 0.200
Polyphenylene sulfide
0.020 - 0.180
Polypropylene
0.025 - 0.150
Polystyrene
0.035 - 0.150
Polyurethane
0.080 - 0.750
The table* shows wall thicknesses that Proto Labs recommends according to resin for injection molding. Please note that thin walls only work on small parts and thicker walls are required where the resin has a long way to flow. Proto Labs' injection molding process makes parts with dimensions from about 0.25 in. to 29.6 in. (6.3mm to 752mm).
*Adapted from www.manufacturingcenter.com.
Wall thickness
Protomold wall thickness
Surface finish
A number of standard finishes are available for injection-molded parts at Proto Labs. Our current finishes include non-cosmetic, low-cosmetic and EDM finishes; bead-blast texturing; and high-end mold polishing.
Standard finishes (from least to most costly):
PM-F0:
Non-cosmetic: finish to Protomold discretion
PM-F1:
Low-cosmetic: most toolmarks removed
PM-F2:
Non-cosmetic: Protomold discretion, EDM finish and/or toolmarks permissible
SPI-C1:
600 grit stone, 10-12 Ra
PM-T1:
Protomold texture, SPI-C1 followed by light bead blast
PM-T2:
Protomold texture, SPI-C1 followed by medium bead blast
SPI-B1:
600 grit paper, 2-3 Ra
SPI-A2:
Grade #2 Diamond Buff, 1-2 Ra
*“PM” in the table signifies a surface finish adjusted to fit the quick-turn injection molding process, where SPI (The Society of the Plastics Industry) denotes an industry-standard finish.
Surface finish
Protomold PM-F0 finish
PM-F0
Protomold SPI-A2 finish
SPI-A2
Protomold T2 finish
PM-T2
PM-F0
SPI-A2
Protomold T2 finish
PM-T2
Radii
Because Proto Labs employs an automated CNC milling process to make the mold for your parts, some part corners will end up with a radius rather than a sharp edge. This does not usually require a change to the model, but the designer is made aware of these radii before the mold is made.
Radii
Protomold radii
Ejector pins
Proto Labs' injection molding process uses ejector pins of various sizes to push the plastic part out of the mold after it has solidified. The sizes and arrangement of these pins are selected to minimize the impact on your part design. Ejector pins range in size from 0.063 in. (1.6mm) to 0.5 in. (12.7mm), with sizes larger than 0.063 in. (1.6mm) preferred.
Ejector pins
Protomold ejector pins
Undercuts
Our molding process supports simple undercuts in your part geometry. Maximum side core dimensions:
Width
Height
Pull
≤ 8.419 in.
≤ 2.377 in
≤ 2.900 in.
≤ 213.84mm
≤60.38mm
≤73.66mm
Undercuts
Protomold undercuts
Proto Labs stocks hundreds of thermoplastic resins for injection molding that offer a variety of benefits for many different applications and industries. See full list of materials.
  • ABS
  • ABS/PC
  • Acetal
  • Acetal Copolymer
  • Acetal Homopolymer
  • ETPU
  • HDPE
  • LCP
  • LDPE
  • LLDPE
  • Nylon 6
  • Nylon 6/12
  • Nylon 66
  • PBT
  • PC/PBT
  • PEEK
  • PEI
  • PET
  • PETG
  • PMMA
  • Polycabonate
  • Polypropylene
  • PPA
  • PPE/PS
  • PPS
  • PS
  • PSU
  • SB
  • TPE
  • TPU
  • TPV
