Liquid Silicon Rubber Part
Liquid Silicone Rubber Injection Molding
Get custom silicone rubber parts within days.
Certifications
ISO 9001:2015 | ITAR Registered | Critical to Quality Inspections
Our liquid silicone rubber (LSR) molding process produces custom prototypes and end-use production parts in 15 days or less. We use aluminum molds that offer cost-efficient tooling and accelerated manufacturing cycles, and stock various grades and durometers of LSR materials.
Common applications for silicone rubber molding:
  • low-volume production
  • bridge tooling
  • pilot runs
  • functional prototyping
Cover of definitive guide to injection molding
Definitive Guide to Injection Molding
This complete reference guide walks you through everything from quoting, design analysis, and shipment to best practices that ensure your model is optimized for molding.
Liquid Silicone Rubber Molding Capabilities
Our basic guidelines for silicone rubber molding include important design considerations to help improve part moldability, enhance cosmetic appearance, and reduce overall production time.
View our design guidelines page for more details
  US Metric
SIZE 12 in. x 8 in. 4 in. 304.88mm x 203.2mm x 101.6mm
VOLUME 13.3 cu. in. 217,948 cu. mm
DEPTH
No greater than 2 in. from any parting line; deeper parts are limited to a smaller outline
No greater than 50.88mm from any parting line; deeper parts are limited to a smaller outline
PROJECTED MOLD AREA 48 sq. in. 30968 sq. mm
Tolerances:
Protolabs can maintain a machining tolerance of +/- 0.003 in. (0.08mm) with a linear tolerance of +/- 0.025 in./in. (0.025mm/mm).
Liquid Silicone Rubber Materials
  • Standard Silicone (30, 40, 50, 60, and 70 durometers)
  • Medical-Grade Silicone
  • Optical-Grade Silicone
  • Fluorosilicone (fuel and oil resistant)
Surface Finish Options
FINISH DESCRIPTION
PM-F0 non-cosmetic, finish to Protolabs' discretion
PM-F1 low-cosmetic, most toolmarks removed
PM-F2 non-cosmetic, EDM permissible
SPI-C1 600 grit stone, 10-12 Ra
PM-T1 SPI-C1 + light bead blast
PM-T2 SPI-C1 + medium bead blast
SPI-B1 600 grit paper, 2-3 Ra
SPI-A2 grade #2 diamond buff, 1-2 Ra
Quality Inspections and Finishing Options
Depending on your application's requirements, you can choose from the following when requesting a quote for your silicone rubber parts.
Quality Inspections available for on-demand manufacturing orders
  • Designing for Manufacturability (DFM) Feedback
  • Scientific Molding Process Development Report
  • In-process CMM inspection and machine monitoring
  • First article inspection (FAI) and process capability report with GD&T
Learn More About Liquid Silicone Rubber Molding
Our guide to liquid silicone rubber (LSR) discusses the injection-molding process of the elastic material and offers guidelines to improve molded LSR parts. While there are some shared similarities to thermoplastic injection molding, LSR is a thermoset material with a unique set of design characteristics.
How Does Liquid Silicone Rubber Molding Work?
Due to the flexible nature of LSR, parts are manually removed from the mold, and thus, ejector pins are not built into the mold design. Like a standard aluminum tool, an LSR molding tool is fabricated using CNC machining to create a high-temperature tool built to withstand the LSR molding process. After milling, the tool is polished by hand to customer specifications, which allows six standard surface finish options.
The finished tool is loaded into an advanced LSR-specific injection molding press that is precision geared for accurate control of shot size to produce the most consistent LSR parts. Since LSR is a thermosetting polymer, its molded state is permanent—once it is set, it can’t be melted again like a thermoplastic. When the run is complete, parts (or the initial sample run) are boxed and shipped shortly thereafter.
Get an online quote and injection molding design analysis today.
