Selective Laser Sintering
Selective laser sintering (SLS) is one of four additive processes available at Proto Labs. During the SLS process, a CO2 laser draws onto a hot bed of thermoplastic powder, where it lightly sinters (fuses) the powder into a solid. After each layer, a roller lays a fresh layer of powder on top of the bed and the process repeats. SLS uses a nylon-based powder similar to actual engineering thermoplastics, so parts exhibit greater toughness and are accurate, but have rough surface and lack fine details. SLS offers a large build volume, can produce parts with highly complex geometries and create durable prototypes.
1 to 50+ parts
Shipped in 1 to 7 days
Parts start at $95
Process
Quoting
When a 3D CAD model of a part has been uploaded and subsequently approved by a customer, their confirmed order is moved into a scheduling and build queue. All of the part files are downloaded and the geometry is analyzed for any potential manufacturability issues. If any issues do arise, a dialog between a Proto Labs representative and the customer will take place to resolve the problem before the actual build begins.
Quoting
Fineline SLS quoting
Build preparation
As the build prep begins, parts are digitally positioned onto the build platform. One of the big differences between selective laser sintering and stereolithography is that SLS does not require parts to be supported during the build process. Because SLS is a powder-based process, the bed of powder itself serves as the support, essentially allowing the parts to be stacked vertically (or in any direction) as they are being built. As such, a support system is not designed into the part before the build begins.
Build prep technicians then go through a layer-by-layer review to ensure a successful build. (With an average build height of 1 to 2 inches, for example, there would be approximately 500 to 1,000 layers.) Once the review is complete, the technicians will digitally create the required amount of part copies needed for a particular order before it is ultimately sent to the SLS machine.
Build preparation
Finline SLS build preparation
Part production
Using a CO2 laser, the SLS machine begins sintering each layer of part geometry into a heated bed of nylon-based powder. After each layer is fused, a powder deposition system (or roller) moves across the bed to distribute the next layer of powder. The process is repeated layer by layer until the build is complete.
Post build
When the build finishes, the entire module is moved into a breakout station. Once the module has adequately cooled, the entire powder bed is raised up and the parts are broken out of the bed. An initial brushing is manually administered to remove a majority of loose powder. Parts then travel to a cabinet where they are bead blasted to remove any of the remaining residual powder before ultimately reaching the finishing department. We will drill out holes as needed, though most holes are designed undersized and do require drilling in SLS. Remaining secondary options (like a primer that can be applied) are much more limited in SLS versus SL.
Post build
Fineline SLS post build
Request More Information
After submitting the form below, we will reach out to provide you with more information about how you can get free design for manufacturability analysis of your part. Our standard follow-up time is within one business day.
First Name
Last Name
Email
Phone
Country Comment
I agree to receive email messages containing service updates and design tips from Proto Labs, Inc. and its affiliates.
You can withdraw consent at any time. Please refer to our privacy policy for more details or contact us with any questions.
