New Silicone Rubber Materials
Posted On May 25, 2017 By Tony Holtz
We’ve expanded our selection of liquid silicone rubber (LSR) materials, which have some distinct elastic and optical advantages over certain thermoplastics. In addition to three durometers of general-use Elastosil LSR, and medical- and optical-grade Dow Corning materials, we now have two new durometers of Elastosil and a fuel-resistant flourosilicone material at Protolabs.
Elastosil LSR
Elastosil LSR is a great general-use material that has good moldability characteristics, a good overall appearance and is transparent until colorant is added. Shore A durometers of 40 and 60 have been added our current offering of 30, 50, and 70 durometers.
Technical specs:
  • 40 durometer Elastosil has a tensile strength of 10.0 N/mm² with a tear strength of 33 N/mm and an elongation break of 610%.
  • 60 durometer Elastosil has a tensile strength of 9.40 N/mm² with a tear strength of 27 N/mm and an elongation break of 340%.
Common uses:
  • Ignition technologies
  • Automotive, when fuels are not present
  • Seals and gaskets
  • Membranes
  • Food contact
Flourosilicone Rubber
We’ve also introduced a fuel- and oil-resistant fluorosilicone (Silastic FL 60-9201), which meets the standards required for some automotive applications. Like other LSR materials, flourosilicone also has high elasticity at low temperatures (-68°F) and high temperature resistance. Operating temperature ranges from -82°F to 347°F under immersive conditions and up to 437°F in dry heat.
Fluorosilicone is available in shore A durometer of 60, which has a tensile strength of 6.5 Mpa with a tear strength of 14 N/mm and an elongation break of 220%.
We’re always adding new plastic, metal and LSR materials, so stay tuned for updates throughout the year. If you have any questions on materials, feel free to contact us directly at 877.479.3680 or [email protected].
