Design Tip
How 3D Printing Materials Measure Up
Comparing injection-molded thermoplastics to ‘thermoplastic-like’ materials in stereolithography
Many factors come into play when comparing the material properties of thermoplastics found in injection molding versus “thermoplastic-like” materials used in an industrial-grade 3D printing technology like stereolithlography (SL).
SL uses a thermoset liquid, not a thermoplastic, which is UV-cured in layers to form final parts. Because of this major difference in fabrication methods, material properties like tensile strength, heat deflection and flexure modulus may differ from SL’s more traditional counterpart. Furthermore, SL produces anisotropic properties where the values for X, Y and Z axis may differ depending on the orientation of the build—a consideration unique to 3D printing processes.
At Protolabs, a thorough selection of thermoplastic-like materials are offered through SL, but what may surprise you is the versatility and range of potential applications for SL parts. We’ll take you through each material and its properties, and compare them with one another (as well as with molded plastics) to help you decide how to best implement SL.
Polycarbonate-Like Materials
Accura 5530 material is transparent in color, temperature tolerant and water resistant. It also is resistant to automotive fluids making it suitable for under-the-hood and electrical applications. Note that secondary operations are required to achieve transparency and the final part will still retain a slight amber hue.
Accura 60 offers the ability for fine detail while providing good stiffness in parts. Common applications include durable prototypes for automotive, consumer electronics and lighting components, as well as medical instruments. Accura 60 has a high tensile strength and modulus making this a good choice to replace polycarbonate (PC) when heat resistance is not critical. However, Accura 60 has the highest moisture absorption rate of the SL materials, which may impact dimensional stability overtime.
Somos NanoTool has an added ceramic filler that increases stiffness and brittleness over other SL materials. Along with stiffness, Nanotool touts the highest temperature resistance compared to most materials offered in SL. It’s regularly used in aerospace and automotive applications that often require greater strength and temperature resistances.
  Accura 5530 Accura 60 Somos NanoTool PC (Molded)
Hardness, Shore D 88 86 93-94 118-120(R-Scale)
Heat Deflection* 338-482°F 127-131°F 496-506°F 250-280°F
Tensile Modulus 3,585 - 3758 MPa 2690-3100 MPa 10,400-11,400 MPa 2,400 MPa
Tensile Strength 47-61 MPa 58-68 MPa 66-80 MPa 50-72 MPa
Flexural Modulus 3,496 - 3634 MPa 2700-3000 MPa 9,960 - 10,200 MPa 2,200 - 2,400 MPa
Flexural Strength 96-108 MPa 87-101 MPa 103-149 MPa 82-93 MPa
Chart 1: Three PC-like materials and one molded PC thermoplastic are compared across six material property categories. Notice how the heat deflection in the PC-like parts are be much lower or have a wider range than the molded PC due to the anisotropic properties discussed earlier. *Heat deflection was measured at 66 psi.
ABS-Like Materials
RenShape SL 7820 has high strength and good dimensional stability, even in high humidity. The material is black and commonly used in automotive parts, consumer packaging, electrical housings and toys due to its impact resistance and ease of secondary finishing that provides the appearance of production quality.
MicroFine Green is a proprietary material at Protolabs, offering an extremely high resolution and build accuracy. MicroFine has a unique opaque green color distinguishing it from other materials. Layer thicknesses of 0.001 in. and feature sizes of 0.002 in. are possible with MicroFine Green to accommodate application that require very small parts.
Somos Watershed XC 11122 is strong, durable, water-resistant ABS-like material. It’s nearly colorless and mimics a clear engineered-grade plastic. Watershed’s high clarity makes it a perfect material for prototyping lenses, flow-visualization models and micro-fluidic parts. Note that secondary operations will be required to get the material completely clear. Watershed will also retain a very light blue hue afterward.
  Accura ABS Black MicroFine Green Somos Watershed ABS (Molded)
Hardness, Shore D 87 85 -- 109 (R-Scale)
Heat Deflection* 122°F 138°F 115-130°F 185-215°F
Tensile Modulus 2,000 - 2,500 MPa 2,100 MPa 2,650 - 2,880 MPa 2,200 - 2,500 MPa
Tensile Strength 39-51 MPa 45 MPa 47-54 MPa 32-42 MPa
Flexural Modulus 2,100 - 2,500 MPa 2,200 MPa 2,040 - 2,370 MPa 1,800 - 2,600 MPa
Flexural Strength 62-80 MPa 74 MPa 63-74 MPa 60-72 MPa
Chart 2: Three ABS-like materials and one molded ABS thermoplastic are compared across six material property categories.
Polypropylene-Like Materials
Accura Xtreme White 200 is comparable to both a polypropylene (PP) and ABS thermoplastic in that it offers strength and durability, lending itself well to application that require snap-fit features. Note that Xtreme White 200 has the lowest heat deflection of the SL materials offered at Protolabs.
Somos 9120 is translucent in appearance, providing excellent resolution and fine detail. You may want to consider Somos 9120 for parts with thin walls or small holes. The PC-like material is also the most flexible SL material at Protolabs, while maintaining its durability. Potential applications include automotive components, electrical housings and medical devices.
  Accura Xtreme White Somos 9120 PP (Molded)
Hardness, Shore D 78-80 80-82 80-100 (R-Scale)
Heat Deflection* 117°F 126-142°F 124-203°F
Tensile Modulus 2,300-2,630 MPa 1,227-1,462 MPa 1,720 MPa
Tensile Strength 45-50 MPa 30-32 MPa 27-40 MPa
Flexural Modulus 2,350-2550 MPa 1,310-1,455 MPa 1,000-1,400 MPa
Flexural Strength 75-79 MPa 44-46 MPa 41 MPa
Chart 3: Two PP-like materials and one molded PP thermoplastic are compared across six material property categories. Notice that properties are fairly similar between each.
Die-Cast Aluminum
FineLine SLArmor uses DSM Somos NanoTool as a base material for 3D printing and has a secondary process that adds a thin metal coating that provides the look, feel and strength of a metal part without any added weight. SLArmor’s nickel plating adds strength and temperature resistance to SL parts that previously was not achievable. Note that we typically layer either 0.002 in. or 0.004 in. of plating thickness on parts.
   SLAmor Die Cast Aluminum
10% metal volume 20% metal volume 30% metal volume
Heat Deflection 122-516°F >500°F
Tensile Strength 100 MPa 145 MPa 200 MPa 300 MPa
Elongation at Break 0.9% 1.04% 1% 2-5%
Mod. Of Elasticity 21,000 MPa 31,000 MPa 42,000 MPa 70,000 MPa
Chart 4: Three grades of nickel-plated SLArmor and die-cast aluminum compared across four material property categories. Protolabs tests to ASTM D638M standards.
Parting Notes
Unlike thermoplastics, long-term exposure to UV light and moisture will alter the appearance and mechanical properties of SL materials if they are not protected by plating or painting. Over time, you may experience part warpage, yellowing and brittleness in some parts. SL parts are not intended for long-term use in many instances, but understanding the short-term benefits of having highly cosmetic and functional parts to use during early prototyping can greatly benefit you.
Remember to work closely with the 3D printing experts to ensure that build orientation, anisotropism and material properties are optimized. Adjusting the direction in which the part is built can often improve the material properties and clarity of the part.
Dive deeper into stereolithography at For questions on 3D printing or any of our services, please contact a customer service engineers at or 877-479-3680.
Have a design ready for 3D printing? Upload it now for an instant quote.
