Metal 3D Printing Service
Certification + Compliance
  • Prototyping in production-grade materials
  • Complex geometries
  • Functional, end-use parts
  • Reducing metal components in an assembly
metal 3d printed part with internal channels
We hope you find this guide helpful. If the file did not download, you can find it here.
Metal 3D Printing Guide
Jump start your metal 3D printing with this guide that covers material selection, design, post-processing, and quality inspections.
Metal 3D Printing Capabilities
Our basic guidelines for metal 3D printing include important design considerations to help improve part manufacturability, enhance cosmetic appearance, and reduce overall production time.
Print it Better
Get high quality 3D-printed parts fast with support from engineers who know additive inside and out. Build high-performing, reliable parts with six 3D printing technologies and 60+ materials.
Compare Material Properties
Materials Resolution Condition Ultimate Tensile Strength
(ksi)
Yield Stress
(ksi)
Elongation
Hardness
Stainless Steel
(17-4 PH)
20 μm Solution & Aged (H900) 199 178 10 42 HRC
30 μm Solution & Aged (H900) 198 179 13 42 HRC
Stainless Steel
(316L)
20 μm Stress Relieved 82 56 78 90 HRB
30 μm Stress Relieved 85 55 75 88 HRB
Aluminum
(AlSi10Mg)
20 μm Stress Relieved 39 26 15 42 HRB
30 μm Stress Relieved 50 33 8 59 HRB
40 μm Stress Relieved 43 27 10 50 HRB
Cobalt Chrome
(Co28Cr6Mo)
20 μm As Built 182 112 17 39 HRC
30 μm As Built 176 119 14 38 HRC
Inconel 718 20 μm Stress Relieved 143 98 36 33 HRC
30 μm Stress Relieved 144 91 39 30 HRC
30 μm Solution & Aged per AMS 5663 208 175 18 46 HRC
60 μm Stress Relieved 139 83 40 27 HRC
60 μm Solution & Aged per AMS 5663 201 174 19 45 HRC
Titanium
(Ti6Al4V)
20 μm Stress Relieved 153 138 15 35 HRC
30 μm Stress Relieved 144 124 18 33 HRC
20 μm = high resolution (HR)
30, 40, and 60 μm = normal resolution (NR)
(MPa)
Yield Stress
(MPa)
Elongation
Hardness
Stainless Steel
(17-4 PH)
20 μm Solution & Aged (H900) 1,372 1,227 10 42 HRC
30 μm Solution & Aged (H900) 1,365 1,234 13 42 HRC
Stainless Steel
(316L)
20 μm Stress Relieved 565 386 78 90 HRB
30 μm Stress Relieved 586 379 75 88 HRB
Aluminum
(AlSi10Mg)
20 μm Stress Relieved 268 180 15 46 HRB
30 μm Stress Relieved 345 228 8 59 HRB
40 μm Stress Relieved 296 186 10 50 HRB
Cobalt Chrome
(Co28Cr6Mo)
20 μm As Built 1255 772 17 39 HRC
30 μm As Built 1213 820 14 38 HRC
Copper
(CuNi2SiCr)
20 μm Precipitation Hardened 496 434 23 87 HRB
Inconel 718 20 μm Stress Relieved 986 676 36 33 HRC
30 μm Stress Relieved 993 627 39 30 HRC
30 μm Solution & Aged per AMS 5663 1434 1207 18 46 HRC
60 μm Stress Relieved 958 572 40 27 HRC
60 μm Solution & Aged per AMS 5663 1386 1200 19 45 HRC
Titanium
(Ti6Al4V)
20 μm Stress Relieved 1055 951 15 35 HRC
30 μm Stress Relieved 993 855 18 33 HRC
Below is our available metal alloys for 3D printing. Various heat treatments are available depending on material.
Stainless Steel (17-4 PH)
Stainless Steel 17-4 PH is a precipitation hardened stainless steel that is known for its hardness and corrosion resistance. If needing a stainless steel option, select 17-4 PH for its significantly higher tensile strength and yield strength, but recognize that it has far less elongation at break than 316L. Final parts built 17-4 PH receive vacuum solution heat treatment as well as H900 aging.
Primary Benefits
  • Heat treated for full hardness and strength
  • Corrosion resistance
Finishing Options
Standard
Brushed 150
Brushed 220
Brushed 400
Satin
Polished
Stainless Steel (316L)
Choose 316L when stainless steel flexibility is needed; 316L is a more malleable material compared to 17-4 PH. Final parts built in 316L receive stress relief application.
Primary Benefits
Finishing Options
Standard
Brushed 150
Brushed 220
Brushed 400
Satin
Polished
Aluminum (AlSi10Mg)
Aluminum (AlSi10Mg) is comparable to a 3000 series alloy that is used in casting and die casting processes. It has good strength -to-weight ratio, high temperature and corrosion resistance, and good fatigue, creep and rupture strength. AlSi10Mg also exhibits thermal and electrical conductivity properties. Final parts built in AlSi10Mg receive stress relief application.
Primary Benefits
  • High stiffness and strength relative to weight
  • Thermal and electrical conductivity
Custom Finishing Options
Standard
Brushed 150
Brushed 220
Brushed 400
Satin
Polished
Inconel 718
Inconel is a high strength, corrosion resistant nickel chromium superalloy ideal for parts that will experience extreme temperatures and mechanical loading. Final parts built in Inconel 718 receive stress relief application. Solution and aging per AMS 5663 is also available to increase tensile strength and hardness.
Primary Benefits
  • Oxidation and corrosion resistance
  • High performance tensile, fatigue, creep, and rupture strength
Standard
Brushed 150
Brushed 220
Satin
Cobalt Chrome (Co28Cr6Mo)
Cobalt Chrome (Co28Cr6Mo) is a superalloy comprised primarily of cobalt and chromium. It's high tensile strength and resistance to creep and corrosion makes it a good material choice for aerospace components and medical instrumentation.
Primary Benefits
  • High performance tensile and creep
Standard
Brushed 150
Brushed 220
Brushed 400
Satin
Polished
Titanium (Ti6Al4V)
Titanium (Ti6Al4V) is a workhorse alloy for direct metal laser sintering. When measured against Ti grade 23 annealed, the mechanical properties of Ti6Al4V are comparable to wrought titanium for tensile strength, elongation, and hardness.
Primary Benefits​
  • High temperature and corrosion resistance
Standard
Brushed 150
Brushed 220
Brushed 400
Satin
Polished
Post-Processing Capabilities for Metal 3D-Printed Parts
Improve strength, dimensional accuracy, and cosmetic appearance of final metal components with DMLS for production.
Surface Finishing
  • 3- and 5-axis milling
  • Turning
  • Custom Finishing
    • Brushed (150, 220, 400)
    • Satin
    • Polished
  • Passivation
  • Wire EDM
  • Tapping and reaming
Heat Treatments
  • Stress relief
  • NADCAP heat treatment
  • Hot isostatic pressing (HIP)
  • Solution annealing
  • Aging
Mechanical Testing
  • Tensile
  • Rockwell Hardness
Powder Analysis & Material
  • Traceability
  • Chemistry
  • Particle size and distribution analysis
Why Use Metal 3D Printing?
See how metal additive manufacturing technology can be used to reduce components within an assembly, fabricate complex geometries, and ultimately save you time and costs.
When the build finishes, an initial brushing is manually administered to parts to remove a majority of loose powder, followed by the appropriate heat-treat cycle while still fixtured in the support systems to relieve any stresses. Parts are removed from the platform and support structures are removed from the parts, then finished with any needed bead blasting and deburring. Final direct metal laser sintering parts are near 100 percent dense.
X line Metal 3D Printer
Large Format Metal 3D Printing
Our large format metal 3D printers can build metal parts as large as 31.5 in. x 15.7 in. x 19.7 in. in Aluminum and Inconel. Large, 3D-printed parts are often used in industrial settings, aerospace applications, automotive, and energy.
Additional Resources
