Design Guidelines: Multi Jet Fusion
Our basic guidelines for Multi Jet Fusion include important design considerations to help improve part manufacturability, enhance cosmetic appearance, and reduce overall production time.
Size
Maximum Dimensions
| Normal Resolution | 11.1 in. x 14.9 in. x 14.9 in. |
| Normal Resolution | 284mm x 380mm x 380mm |
Accuracy
| Layer Thickness | 0.00315 in. |
| Minimum Feature Size | 0.020 in. |
| Layer Thickness | 80 microns |
| Minimum Feature Size | 0.5mm |
For well-designed parts, tolerances of +/- 0.012 in.
(0.30mm) plus +/- 0.002 in./in. (0.002mm/mm) for each additional inch can typically be achieved. Note that tolerances may change depending on part geometry.
We offer a commercial-grade unfilled Nylon 12 material that creates durable parts with consistent mechanical properties. A standard dyed black color is offered.
Surface Finishes
| STANDARD | A bead blast removes all powder and leaves a consistent overall texture. Parts are then dyed a standard black color. |
| CUSTOM |
Secondary options include a primer that can be applied as well as taps and inserts. |
Equipment
We use HP Jet Fusion 3D 4210 machines that are capable of accelerated build speeds when compared to other powder-based additive manufacturing technology. The HP 3D printers produce commercial-grade parts with enhanced surface finishes and improved mechanical properties compared to other 3D printing technology.
GET A QUOTERequest More Information
Thanks! We’ve received your message and a member of our team will be in touch with you shortly.
You can find more information about Protolabs here:
Thanks for your interest in Protolabs. Please let us know how we can provide more information on our services. Once we receive your comments, an applications engineer from our team will follow-up as soon as possible.
If you have a 3D CAD model of your part ready, upload it online now to receive an interactive quote with free design for manufacturability feedback within hours.
