Design Guidelines: Selective Laser Sintering
Our basic guidelines for selective laser sintering include important design considerations to help improve part manufacturability, enhance cosmetic appearance, and reduce overall production time.
Size
Maximum Dimensions
| PA12 | 19 in. x 19 in. x 17 in. |
| PA11, PA12-GF, PA12-MF | 10.6 in. x 12.6 in. x 16 in. |
| PA12 | 482mm x 482mm x 431mm |
| PA11, PA12-GF, PA12-MF | 269mm x 304mm x 406mm |
Accuracy
| Layer Thickness | 0.004 in. |
| Minimum Feature Size | 0.030 in. |
| Layer Thickness | 0.1016mm |
| Minimum Feature Size | 0.762mm |
For well-designed parts, tolerances of ±0.010 in. (0.25mm) plus ±0.0015 in./in. (0.0015mm/mm) for each additional inch can typically be achieved. Note that tolerances may change depending on part geometry.
- PA12 White (PA650)
- PA11 Black (PA850)
- PA12 40% Glass-filled (PA614-GS)
- PA12 Mineral-filled (PA620-MF)
Surface Finishes
| STANDARD | Bead blast to remove all powder, which leaves a consistent overall texture. |
| CUSTOM |
Secondary options include a primer or dye color that can be applied as well as taps and inserts. |
Equipment
Our SLS equipment includes sPro140 machines, which have the world’s largest sintering build volume, and feature fully digital high-speed scanning systems, unparalleled process consistency, and closed systems for powder blending and delivery for reliable part quality. We also use sPro60 machines, which allow for multiple materials and high throughput.
GET A QUOTERequest More Information
Thanks! We’ve received your message and a member of our team will be in touch with you shortly.
You can find more information about Protolabs here:
Thanks for your interest in Protolabs. Please let us know how we can provide more information on our services. Once we receive your comments, an applications engineer from our team will follow-up as soon as possible.
If you have a 3D CAD model of your part ready, upload it online now to receive an interactive quote with free design for manufacturability feedback within hours.
