Comparing Aluminium Alloys: Find the Right Material for Your Part
Aluminium is a common and popular metal that’s used in a stunningly wide range of parts and products: automotive parts, aerospace components, boat and marine gear, consumer electronics including smart phones, industrial machinery parts, HVAC systems, the list goes on. It’s also the material most commonly requested by our customers.
Engineers and product designers frequently turn to aluminium and many of its alloys to design both prototypes and end-use parts in a variety of industries. Choosing the right aluminium alloy when designing parts is critically important because different alloys possess significantly different properties, which directly impact the part's performance, manufacturability, durability, and cost. Alloys vary in mechanical and physical properties, manufacturing/fabrication characteristics, cost, and response to the application environment.
Aluminium Alloy Properties
Aluminium has a high strength-to-weight ratio, making it lightweight, yet strong and flexible. It’s also affordable, corrosion-resistant, and works well in a multitude of applications. Most commonly, aluminium is alloyed with other elements such as silicon, magnesium, chromium, copper, zinc, and manganese.
Aluminium alloys are often used in cars because of the material’s versatility. Aluminium’s formability and corrosion resistance make it easy to work with and shape, but its structural soundness addresses the most important requirement for car bodies. Strength is important, but car bodies must be lightweight, affordable to produce, resistant to rust, and have the attractive qualities consumers seek, such as exceptional surface finishing characteristics. Aluminium nicely fits the bill.
The same holds true with aerospace parts. Aluminium alloys are often a preferred material for aerospace designs, again because of aluminium’s corrosion-resistance properties and high strength capabilities. Compared to steel, it is a lightweight option and an ideal material for a wide range of aircraft components and aerospace applications.
Lightweighting is a core need of both the automotive and aerospace industries.
With cars, light-weighting helps reduce emissions and meet improved fuel economy standards.
For aerospace, the use of aluminium alloys dramatically decreases the weight of an aircraft because it is significantly lighter than steel, allowing aircraft to either carry more weight or increase fuel efficiency. For instance, a 20% weight reduction in a Boeing 787 is expected to generate a 10–12% improvement in fuel efficiency. Along these lines, common applications in aerospace abound—many, but not all, of which, are metal: Fuel nozzles, heat exchangers, manifolds, turbo pumps, liquid and gas flow components, conformal cooling channels, fasteners, and more.
Comparing Common Aluminium Alloys
Aluminium, as a pure element, presents many desirable properties. However, by itself, aluminium might not be strong enough for a high-durability use or purpose. Accordingly, aluminium can be combined with other elements to form alloys, which are more durable and suitable for industrial applications.
And what do all of those numbers in the alloy name signify? The aluminium series names elements with four numerical digits where the first digit represents the principal alloying element, the second digit indicates a modification of a specific alloy, and the third and fourth digits are arbitrary numbers assigned to specific alloys in the series.
| Material | Process | Tensile Strength | Elongation | Hardness |
| AL 6061-T651 | CNC Milling CNC Turning Sheet Metal Fabrication |
40 ksi 276 MPa |
17% | 95 HBW 10/500 |
| Al 7075-T651 | CNC Milling CNC Turning |
83 ksi 572 MPa |
11% | 85 HBW 10/500 |
| Al 5052-H32 | Sheet Metal Fabrication | 33.34 ksi 228 MPa |
12% | 60 HBW |
| Al 5754 (Available through Protolabs Network) |
Sheet Metal Fabrication | 20-40 ksi 140-280 MPa |
≥2% | ≥50 HRB |
| Al 2024 | CNC Milling CNC Turning |
68 ksi 469 MPa |
19% | 120 HRB |
| Al (AlSi10Mg) | 3D Printing: DMLS High resolution (20 μm) |
39 ksi 268 MPa |
15% | 42 HRB |
| Al (AlSi10Mg) | 3D Printing: DMLS Normal resolution (30 μm) |
50 ksi 345 MPa |
8% | 59 HRB |
| Al (AlSi10Mg) | 3D Printing: DMLS Large Format (40 μm) |
42 ksi 296 MPa |
10% | 50 HRB |
Aluminium Materials Available Through Protolabs Factories
This high strength alloy adds chromium to the mix to develop good stress-corrosion cracking resistance. It is the go-to alloy for aerospace parts, military applications, bicycle equipment, camping and sports gear because of its lightweight yet strong characteristics. While popular due to its strength, aluminium 7075 suffers from poor weldability and it can be quite brittle compared to some lower-strength alloys.
Aluminium 5083-H111 (3.3547 or AlMg4.5Mn0.7) is a high-strength, non-heat treatable aluminium alloy added to our CNC service materials. Known for its excellent resistance to saltwater and industrial chemicals due to its high magnesium content, it offers a strong strength-to-weight ratio and weldability, making it ideal for marine and automotive applications. This addition provides more options for rapid prototyping and low-volume production with fast turnaround times.
This alloy offers excellent weldability, brazeability, corrosion resistance, formability, and machinability. It features good finishing characteristics and responds well to anodising.
This is a widely used, high-strength aluminium alloy with copper as the primary alloying element. Its advantages make it a go-to material for specific demanding applications, particularly in aerospace. It offers a high strength-to-weight ratio, excellent fatigue resistance, good machinability, and is heat treatable. Be aware that it has poor corrosion resistance and is not suitable for welding.
A mainstay of our 3D printing direct metal laser sintering (DMLS) process, this is comparable to the 3000 series alloy that is used in casting and die-casting processes. It has good strength-to-weight ratio, high temperature and corrosion resistance, as well as good fatigue, creep, and rupture strength. AlSi10Mg also exhibits thermal and electrical conductivity properties. Final parts built in AlSi10Mg receive stress relief application.
Aluminium Materials Available Through Protolabs Network
Aluminium 2014 is easily machined and can be hardened to get strengths comparable to steel but is prone to corrosion. Suitable for aerospace applications.
Aluminium 2017 has a higher ductility and formability than Aluminium 2014 and has intermediate strength.
Aluminium 5083 is a strain hardening aluminium alloy with excellent corrosion resistance. Suitable for marine applications. Can be welded.
Alloy 6060 offers good strength, relatively good corrosion resistance and is suitable for decorative anodising.
Aluminium 6063 has good mechanical properties and can be heat treated. Suitable for aerospace applications. Can be welded.
Aluminium 6082 has very similar composition and properties to 6061, with slightly higher tensile strength. Compliant with British Standards.
Aluminium 7050 has excellent mechanical properties with good ductility, high strength, toughness, and good resistance to fatigue. Suitable for aerospace applications.
Aluminium MIC6 is a lightweight material that can be easily machined at high speed and is free from tension, contaminants, and porosity.
Aluminium 6061 (CNC) is the most popular aluminum alloy. It has good strength-to-weight ratio, excellent machinability and natural corrosion resistance.
Aluminium 7075-T6 (CNC) is an aerospace-grade material with excellent strength-to-weight ratio and strength and hardness comparable to steels.
Aluminium 5052 is a strain hardening aluminium alloy with excellent corrosion resistance. Suitable for marine applications. Can be welded.
Aluminium 2024 is a high-strength alloy with excellent fatigue resistance. Suitable for aerospace applications.
Aluminium 6061 vs. Aluminium 7075
These two alloys are the most requested by our CNC machining customers so we receive a lot of questions comparing the two. Here’s how they score. The primary advantage of 7075 lies in its exceptionally high strength-to-weight ratio, significantly exceeding that of 6061, making it ideal for high-stress applications like aerospace structures and performance sporting equipment.
However, this superior strength comes with major trade-offs: 7075 exhibits poor weldability using common fusion techniques, has lower general corrosion resistance, is susceptible to stress corrosion cracking, and is typically more expensive and less ductile than 6061. In contrast, 6061 offers a more balanced profile with good strength, excellent weldability, superior corrosion resistance, better formability, and lower cost, making it a versatile workhorse alloy suitable for a vast range of general structural, marine, automotive, and consumer applications where the extreme strength of 7075 is not required.
Finishing Aluminium Parts
First, let’s look at finishing options for CNC-machined aluminium parts.
Anodising is one of the most common finishing options, offering strong corrosion protection and enhancing the overall appearance of metal parts. Three types of aluminium anodising are available from Protolabs:
- Chromic Acid (Type I): Provides a whisper-thin but still durable coating. Commonly used for welded parts and assemblies, and as a primer before painting. Like all anodised surfaces, it is non-conductive.
- Sulfuric Acid (Type II): Harder than Type I, it offers an exceedingly durable finish. Usage examples include carabiner hooks, flashlight handles, motorcycle parts, and hydraulic valve bodies.
- Hard Anodise or Hardcoat (Type III): This is the thickest and hardest anodise available and it has a wide range of applications for parts and products in automotive, aerospace, heavy equipment, marine, general manufacturing, and defense industries.
Another option is plating, which electrically bonds protective elements to the aluminium. Plating is available only through Protolabs Network or when you order complete prototype parts. Adding plating often means adding lead time, so keep that in mind. Also note that plating is one of the more expensive finishing options. Here’s what’s available:
| Type of Plating | Added Lead Time | |
| Anodising | Clear anodise Type II Class 1 | None |
| Black anodise Type II Class 2 | None | |
| Red anodise Type II Class 2 | 2 days | |
| Blue anodise Type II Class 2 | 2 days | |
| Clear Chromate | Type II Class 1A | none |
| Type II Class 3 | none | |
| Yellow Chromate | Type II Class 1A | none |
| Type III | 2 days | |
| Nickel | Class 1 | 3 days |
| Zinc | Clear and yellow | 3 days |
| Titanium anodising | n/a | 3 days |
| Powder coating | n/a | 5 days |
| Black oxide | n/a | 5 days |
For a tough, aesthetic finish, you can choose an application of powder coating on your parts. It leaves a somewhat protective layer of polymer-based coloured powder.
Interestingly, many aluminium alloys tend to be self-healing when exposed to air or oxygen. With this natural passivation process, any exposure causes the metal to form a layer of aluminium oxide on its surface, which acts as a barrier to avoid further material degradation.
Main Takeaways
Some customers ask us what the best all-purpose aluminium is. It’s a tough choice because choice of alloy is entirely predicated on what your part will be exposed to in each product. That said, many people consider aluminium 6061 to be the most well-rounded aluminium, balancing strength, corrosion resistance, weldability, and to machine or fabricate. While it costs a bit more, it offers solid performance across a range of attributes.
If cost-efficiency is your biggest concern, note that less expensive alloys may not provide the lifespan your product requires, so choose carefully, grounded in that knowledge. In terms of strength, 7075 is the strongest alloy we offer, which is why it’s often used in aerospace applications.
