07/10/2025
Properties of Mild Steel
From automotive brackets to industrial fixtures, mild steel is a mainstay of modern manufacturing because it is affordable, machinable, and dependable. Need a material that’s strong, low-cost, and simple to work with? Mild steel ticks all the boxes. This type of low-carbon steel is widely used for everything from prototypes to full production, making it a great option for CNC machining across many industries.
What is Mild Steel
Mild steel is a type of low‑carbon steel that contains about 0.05–0.25% carbon. This low carbon content makes it flexible, easy to weld, and strong enough for most projects. Softer than higher‑carbon steels, it machines easily and won’t wear out tools quickly.
Mild Steel in Manufacturing
Mild steel is a top choice for CNC machining and sheet metal work. Engineers pick it for automotive parts, beams, and fixtures when they need strong, affordable material. It’s less suited for parts that need very high hardness or strong corrosion resistance, where alloys or stainless steel work better. But for the vast majority of everyday manufacturing needs, mild steel delivers the right mix of strength, cost-effectiveness, and reliability.
Types of Mild Steel
Different grades of mild steel cater to specific manufacturing requirements, each offering unique properties for various applications.
  • S275: General-purpose grade with 275 MPa minimum yield strength, ideal for structural and engineering applications
  • S355: Higher strength option with improved mechanical properties while maintaining excellent formability
  • Free-cutting grades: Enhanced with sulphur or lead additives for superior machinability and faster cycle times
  • Hot-rolled variants: Cost-effective option for less precise applications requiring good formability
  • Cold-rolled grades: Superior surface finish and dimensional accuracy for precision components
Mild steel is one of the many metals available through Protolabs Europe, and there are additional mild steel options also available through Protolabs Network.
Grade Description  Tensile Strength (MPa)  Yield Strength (MPa)  Young's Modulus (GPa) Elongation (%)  Available Through
S275JR  Low carbon structural steel with good machinability and weldability  450-580  265-340  217  14-20  Protolabs & Protolabs Network
A36  Common structural steel suitable for industrial applications  400-550  250-290  200  20-23  Protolabs Network
S235JR  Hot-rolled structural steel with good plasticity and weldability  360-510  235-295  210  17-20  Protolabs Network
1045   Medium carbon steel with good weldability and machinability  625-780  415-530  205 12-17  Protolabs Network
S355J2  Higher strength structural steel with high tensile strength  510-680  355-395  210  20-22  Protolabs Network
C45  Medium carbon steel with good strength and impact resistance  630-780  430-580  210 14-17  Protolabs Network
1018  General-use alloy with good machinability and weldability  440-500  370-415  205 15-20  Protolabs Network
Material Comparison: Mild Steel vs. Stainless Steel vs. Aluminium
Understanding how mild steel compares to other common engineering materials helps inform material selection decisions for your manufacturing projects.
Property  Mild Steel  Stainless Steel  Aluminium
Density 7.85 g/cm³  8.0 g/cm³  2.70 g/cm³
Tensile Strength  400-550 MPa  515-827 MPa  90-300 MPa
Yield Strength  250-400 MPa  207-310 MPa  35-270 MPa
Machinability  Excellent  Good Excellent
Corrosion Resistance  Poor (requires coating)  Excellent  Good
Cost Low  High Medium
Weldability Excellent  Good Good
Advantages of Using Mild Steel
Mild steel is popular because it’s practical and easy to work with, helping keep projects cost-effective and efficient.
  • Low-cost: Around 30–50% cheaper than stainless steel, making it a smart choice for large projects.
  • Available in many forms: Comes in sheets, plates, bars, and sections making it easy to match with different project needs.
  • Formable: High ductility lets it handle deep drawing and intricate designs without cracking.
  • Strong: A good strength-to-weight ratio makes it work where durability is required like for automotive brackets, industrial fixtures, and structural components.
  • Easy to weld: Low carbon content means strong, reliable joints without complicated prep so it’s ideal for assemblies.
  • Good machinability: Cuts cleanly for CNC millingturning, and other processes.
  • Repairable: If something breaks, it can be welded or mechanically fixed, extending part life and reducing replacement costs.
Common Applications of Mild Steel
Mild steel finds use across many sectors because its properties match the needs of these industries.
  • Automotive: Strength at low cost makes it work for chassis parts, brackets, and panels.
  • Industrial Equipment: Easy machining and availability in large sizes suit machine frames, conveyors, and tooling bases.
  • Construction & Architecture: Weldability and ductility support structural steelwork, reinforcement, and safety barriers where strong, reliable joints matter.
  • Consumer Electronics: Formability and finishing options deliver durable, cost-effective parts and fittings with good aesthetics.
Mechanical Properties of Mild Steel
The low carbon content gives mild steel its trademark balance of strength, ductility, and ease of machining.
Property Typical Range / Value  Why it Matters
Carbon content  0.05% – 0.25%  Low carbon means excellent ductility and weldability.
Tensile strength  400 – 550 MPa  Provides enough structural capability for most general uses.
Yield strength  250 – 400 MPa  Varies with grade and treatment; defines load before permanent deformation.
Hardness  120 – 200 HB (Brinell)  Soft enough for good machinability with standard tools.
Elastic modulus  ~200 GPa  Predictable stiffness for design calculations.
Elongation  20 – 25%  Can deform significantly before fracture, adding toughness.
Common Post-Processes
Mild steel can be treated in different ways to boost its performance and lifespan.
Heat Treatments
  • Case hardening: Creates a hard, wear-resistant surface while maintaining a tough, ductile core.
  • Normalising: Refines grain structure and relieves stress from machining operations.
  • Anneeling: Reduces hardness for improved formability and machinability.
  • Stress relieving: Eliminates internal stresses without altering mechanical properties.
Surface Protection
  • Zinc plating: Cost-effective corrosion protection for indoor and mild outdoor use.
  • Powder coating: Tough, good-looking finish with strong impact and chemical resistance.
  • Paint: Flexible option with lots of colours and textures.
  • Hot-dip galvanising: Best protection for outdoor and harsh environments.
In practice, engineers pick finishing options based on end use: case hardening for wear, galvanising for outdoor parts, powder coating for when looks matter.
Mild Steel for Prototyping & Production
Mild steel works well from first ideas to final parts because it’s affordable, predictable, and easy to scale.
  • Prototyping: Readily available and low-cost, so it’s easy to test and refine designs quickly. Lead times from as fast as one day mean engineers can move from concept to part without delay.
  • Production: The same setups scale smoothly into larger runs. Stable supply supports fast lead times, consistent material properties deliver repeatable quality, and cost advantages increase with volume.
Factors to Consider When Choosing Mild Steel
When picking the right mild steel grade, keep these elements in mind:
  • Environment: Will the part face moisture, outdoor use, or high heat?
  • Mechanical needs: What strength, ductility, or fatigue resistance does it require?
  • Manufacturing fit: Does it need to machine easily, weld cleanly, or form into complex shapes?
Quick Decision Tree
  • Need the lowest cost for general parts? → S235JR or A36
  • Need higher strength for load-bearing components? → S355J2
  • Need wear resistance for shafts, gears, or heavy-duty parts? → 1045 or C45
  • Need a balance of machinability and strength for precision parts? → 1018
Not sure which grade is right? Our engineering team can help. With deep experience in manufacturing metal parts, we’ll match the best option to your project. Reach out at [email protected].
What is mild steel best used for?
It’s a go-to when you need a balance of strength, easy machining, and low-cost. You’ll see it in car parts, industrial equipment, building structures, and everyday components where corrosion resistance isn’t a big concern.
Can mild steel be heat treated?
Yes. Processes like normalising, case hardening, and stress relieving all work. Just note that it won’t harden all the way through because of the low carbon content.
Does mild steel rust?
Yes, unless it’s protected with coatings like paint, powder coating, zinc plating, or galvanising. That’s why surface protection is often added for outdoor or moisture-prone environments.
Get Started
Ready to use mild steel's many advantages for your next project? Upload your CAD files for instant pricing and lead times on high-quality mild steel components.
