10/10/2025
Steel Composition Explained: Properties, Grades & Applications
From skyscrapers to surgical tools, steel shapes our world. Find out what goes into making it, and how different grades unlock different properties.
Steel is one of the world’s most important engineering metals, used in construction, automotive, aerospace, medical devices and countless everyday products. Its appeal comes from the way its composition can be adjusted to deliver the right balance of strength, ductility, toughness and corrosion resistance.
This article will explain what steel is made of and how different compositions translate into performance on the shop floor and in the field.
What Is Steel Made of?
Steel is an iron-carbon alloy, usually containing 0.05% to 2% carbon by weight. Carbon strengthens the iron while keeping it workable, and additional elements like manganese, nickel, chromium and molybdenum are added to enhance properties such as hardness, weldability and corrosion resistance.
While iron provides the base structure, it's the carbon and these other alloying elements that transform it into a material strong enough for jet engines, precise enough for surgical instruments, and versatile enough for everyday manufacturing.
Understanding steel composition helps you select the right grade for your project, whether you need corrosion resistance or high strength.
Steel Performance and Manufacturability
Steel can be CNC machined, CNC turned, fabricated, or even 3D printed through DMLS. Its manufacturability in each of these processes depends largely on its carbon content, which influences hardness, ductility, and ease of machining.
  • Low-carbon steels (under 0.3% carbon) are easier to machine, weld, and form, making them ideal for sheet metal work and general fabrication.
  • Medium-carbon steels (0.3% to 0.6%) offer a balance between strength and workability, commonly used in machinery parts.
  • High-carbon steels (0.6% to 1.4%) provide excellent hardness and wear resistance but become more brittle and harder to machine.
Think of it as a sliding scale. More carbon results in steel that’s harder and stronger, but less forgiving. Your application dictates where on that scale you need to land.
Types of Steel
Steel is not one material but a family of alloys. Common categories include:
  • Carbon steel: Primarily iron and carbon. Cost-effective, strong, but prone to corrosion.
  • Alloy steel: Includes elements like nickel, chromium or vanadium for improved strength, toughness or heat resistance.
  • Mild steel: A low-carbon subtype of carbon steel (<0.3% carbon) that is easy to weld and form, commonly used in general fabrication.
  • Stainless steel: Contains at least 10.5% chromium for corrosion resistance.
  • Maraging steel: High-alloy, low-carbon steel that gains strength through aging rather than carbon content. Used for high-performance tooling and precision parts where toughness and low distortion matter.
  • Tool steel: High-carbon steel engineered for edge retention, wear resistance and durability in cutting and forming tools. Ideal when hardness and abrasion resistance are the priority. Learn more in our tool steel manufacturing blog.
Properties Linked to Composition
Different elements in the mix give steel different behaviours, and each one plays a role:
  • Strength and hardness: Carbon does most of the heavy lifting here, while alloying elements like chromium and molybdenum can boost strength even further. Heat treatment can then dial those properties up or down.
  • Toughness: This is all about absorbing impact without cracking. Steel with more nickel is better at enduring colder conditions.
  • Corrosion resistance: Chromium is the key player. Once you hit about 10.5%, it forms a protective layer on the surface. Molybdenum adds extra protection in harsher environments like salt or chemicals.
  • Machinability: Small additions of sulphur or phosphorus help chips break cleanly during machining. Grade 303 stainless, available through Protolabs Network, is particularly good at this.
  • Weldability: The more carbon a steel has, the trickier it is to weld. Low-carbon steels weld easily, while higher-carbon grades may need preheating or specific techniques to avoid cracking.
  • Magnetism: Most carbon and alloy steels are magnetic. Austenitic stainless steels like 304 and 316 are generally non-magnetic, while martensitic grades such as 17‑4 PH are magnetic.
Heat Treatment Options
Heat treatment adjusts steel's microstructure to achieve specific properties. The process you choose lets you fine-tune performance:
  • Annealing: Softens the metal and makes it easier to work with. It’s useful when you want to relieve stress or get the material ready for forming.
  • Normalising: Brings the grain structure back into balance so the steel behaves consistently. It’s often used after machining or forging.
  • Quenching and tempering: First you harden the steel by cooling it fast, then you temper it to bring back some flexibility. Choose this when you need strength without the brittleness.
  • Case hardening: Hardens just the outside while keeping the inside tougher and more flexible. It’s a good fit for gears, shafts and fasteners.
Finishes and Corrosion Protection
Even steels with good corrosion resistance can benefit from protective finishes. Protolabs offers a range of finishing options to enhance both performance and appearance:
  • Passivation: Cleans the surface and boosts its natural resistance to rust. It doesn’t change the look or dimensions and is common in medical and food‑grade parts.
  • Black oxide: Adds a thin, non‑reflective layer with light corrosion protection. It’s mainly used for appearance or to cut glare on tools.
  • Zinc plating and galvanising: Puts a protective zinc layer on the surface so the zinc corrodes before the steel. Galvanising is thicker than plating and better for outdoor use.
  • Electroless nickel plating: Adds a hard, even coating that improves wear and corrosion resistance. It works well on complex shapes and functional parts.
  • Powder coating: A durable painted finish in a range of colours. It protects against impact and corrosion but can add thickness to tight‑tolerance features.
Mild Steel Black Oxide
Selecting the Right Steel
Start with your functional requirements, then work backward to your metal material selection. Here's a decision framework:
For Corrosion Resistance
For High Temperature Applications
  • Sustained heat exposure → Alloy steels with chromium and molybdenum (4140, 4340)
  • Extreme temperatures → Tool steels like H13
For Strength and Hardness
For Machinability and Cost
For Lightweight or Complex Geometries
Protolabs Capabilities With Steel
Protolabs provides multiple manufacturing processes for steel parts, from rapid prototyping to production runs
Protolabs Steel Materials
Steel Category  Grades  Strengths  Typical Usage
Stainless Steel  304L, 316L, 17-4 PH  Corrosion-resistant, versatile  Medical, aerospace, general parts
Stainless Steel (DMLS)  316L  Strong, complex geometries possible  Aerospace, automotive, medical
Mild Steel  S275JR  Low cost, easy to weld  Construction, fabrication
Carbon Steel  EN8 Balanced strength and machinability  Shafts, automotive parts
Maraging Steel (DMLS)
Maraging Steel 1.2709  Very high strength  Tooling, high-performance parts
Stainless Steel  304/304L, 316/316L, 303, 17-4 PH, 416, 2205 Duplex, 420, 440C, 430, 301, 15-5  Range from easy machining to wear resistance  Precision, automotive, marine
Mild Steel  1018, C45, S355J2, 1045, S235JR, A36, S275JR   Affordable, easy to machine  Construction, frames
Alloy Steel  1.7131, 4140, 4340, 1215  High strength and wear resistance  Automotive, industrial equipment
Tool Steel  D2, A2, O1, A3, S7, H13  Hard, wear- and heat-resistant  Cutting tools, dies
Steel Sheet Metal
Various grades  Lightweight, formable  Consumer electronics, robotics, industrial equipment
Frequently Asked Questions
What is steel made of?
Iron and carbon, with alloying elements added to adjust performance.
What’s the difference between carbon and stainless steel?
Carbon steels are strong but prone to corrosion. Stainless steels contain chromium for corrosion resistance.
Can steel be 3D printed?
Yes, direct metal laser sintering can build strong, functional parts from stainless steel powder.
Which steel grade is easiest to machine?
Mild steels like 1018 and S275JR are good choices. For stainless steels, 303 is designed for machinability.
Does steel need surface finishing?
Stainless steels often don’t, but carbon and alloy steels usually need coatings like zinc plating or powder coat to protect against corrosion and improve durability.
Get a Quote
Ready to see how steel can strengthen your next design? Upload your part for instant pricing and lead times.
