11/05/2026
Thermoplastic Elastomers (TPE) for Injection Moulding
We sometimes get questions about how thermoplastic elastomers (TPEs) differ from thermoset elastomers and which of the various TPEs would work best for a given part. One of the most fundamental differences between a part made with thermoplastics and one made with thermosets has to do with the chemistry that happens when the part is formed.
What is Thermoplastic Rubber?
Thermoplastic rubber (TPR), often used interchangeably with thermoplastic elastomer (TPE), is a class of materials that combines the flexibility and elasticity of rubber with the processing advantages of plastics. In practical terms, it behaves like rubber under use (stretching and returning to shape), but can be melted, moulded, and reformed like a thermoplastic. This dual nature makes it especially useful in injection moulding, where materials need to flow easily into moulds and solidify quickly into durable, flexible parts.
Unlike traditional rubber, which undergoes irreversible chemical curing, thermoplastic rubber softens when heated and hardens again when cooled. This means it can be reprocessed, reshaped, and even recycled—offering advantages in speed, cost, and sustainability for manufacturing. Because of this versatility, thermoplastic rubber is widely used in applications like seals, grips, overmoulded components, and flexible housings where both durability and a soft-touch feel are important.
Types of Thermoplastic Elastomers
You can break TPEs into six primary categories that differ based on their chemical composition and structure:
  • TPV: Thermoplastic vulcanisates
  • TPU: Thermoplastic urethanes
  • TPO: Thermoplastic olefins
  • SBC: Styrenic block copolymers
  • COPE: Copolyester elastomer
  • PEBA: Polyether block amide
There can be substantial differences between each type of TPE and even the formulation of each subtype, so it’s important to pick the right material when considering part longevity and cost.
TPE Type Trade Names Chemical Resistance Dimensional Stability Density High Tensile Strength? Shore Hardness Range Continuous Use Temp. Limit
TPV
  • Geolast
  • Santoprene
  • Sarlink
good good high moderate 40A to 50D 135℃
TPU
  • Texin
  • Elastollan
  • Desmopan
excellent (for polyester-based formulations) good (with additives) high yes 65A to 80D 120℃
TPO
  • Polytrope
  • Hostacom
  • Thermorun
good good low yes 75A to 80D 120℃
SBC
  • K-Resin
  • Kraton
  • Asaflex
limited good low  low-to-moderate 15A to 50D 110℃
COPE
  • Hytrel
  • Pibiflex
  • Herafle
good good high yes 90A to 80D 140℃
PEBA
  • Vestamid
  • Pebax
good good low yes 80A to 75D 170℃
TPV – Thermoplastic Vulcanisates
This is a hard thermoplastic material with regions of softer cross-linked rubber dispersed throughout its polymer matrix. In general, it offers a “soft” feel, matte finish, and high compression set. Be aware that it is not available in clear.
Applications: Seals, boots and grommets, bumpers, under-hood applications
TPU – Thermoplastic Urethanes
This is a block copolymer with alternating hard and soft regions on its molecular backbone, containing urethane linkages. TPU is noted for its mid-to-high hardness, good clarity, moderate compression set, and good wear, abrasion, and tear resistance. It’s suitable for outdoor applications and must be dried prior to moulding. It’s also rather expensive. TPU is also distinguished as the only TPE available for 3D printing.
Applications: Protective cases, sporting equipment, medical equipment, footwear, in-line skate wheels
TPO – Thermoplastic Olefins
This is a “hard” polyolefin (typically polypropylene) blended with “soft” non-crosslinked rubber regions. Its high hardness yields a tough product with high impact strength. Some grades are weather-resistant. It has a low compression set and, unlike TPU, is comparatively inexpensive.
Applications: Automotive interior: dash, bumpers, roofing
SBC – Styrenic Block Copolymers
These plastics are made up of hard styrene regions and “soft” elastomeric regions arranged in alternating blocks, typically mixed with a more rigid polymer such as polypropylene. There are many different SBCs, so properties are often dependent on specific formulation. SBC is the softest and most flexible of all TPEs. It has a glossy surface, high elongation, good transparency, and good abrasion resistance.
Applications: Soft touch handles, buttons, knobs, grips; gel inserts
COPE – Copolyester Elastomer
COPE is a copolymer consisting of hard crystalline polyester regions and soft amorphous segments. It’s noted for its high temperature resistance, tear strength, and impact strength. It also has good creep resistance and low moisture absorption.
Applications: Furniture, auto boots, bumpers, prosthetics
PEBA – Polyether Block Amide
This copolymer consists of hard polyamide blocks alternating with soft elastomeric blocks. PEBA is noted for its good flex fatigue, creep, and impact resistances. It also does well in high temperatures, has a low compression set.
Applications: Medical equipment, sports equipment, electronics
Applications of Thermoplastic Elastomers
Thermoplastic elastomers are widely used in prototypes and end-use parts due to their flexibility, durability, and ease of processing. Common applications include soft-touch grips for consumer electronics and tools, automotive seals and gaskets, medical device components such as tubing and wearable parts, and overmoulded features that improve ergonomics and waterproofing. TPEs are also popular in IoT devices, packaging, and sporting goods where a combination of elasticity and thermoplastic processability is essential.
Get a Quote
Have a CAD ready? Upload your design to get an instant quote and guidance on the right TPE material for your application.
View Sample Quote
FAQs about Thermoplastic Elastomers and Thermoplastic Rubber
What is TPE? Is it the same as thermoplastic rubber?
Thermoplastic rubber is often used as another name for thermoplastic elastomers (TPE), though technically it usually refers to a subset of TPEs, such as styrenic block copolymers. In most applications, the terms are used interchangeably to describe materials that combine rubber-like flexibility with thermoplastic processability.
Is TPE better than silicone rubber?
It depends on the application. TPEs are easier to process, can be recycled, and are compatible with standard injection moulding equipment. Silicone rubber (a thermoset) offers better heat resistance and long-term stability. The best choice depends on factors like temperature requirements, durability, and cost.
Can TPE be used for overmoulding?
Yes. TPEs are commonly used in overmoulding because they can bond well to rigid thermoplastics, creating soft-touch surfaces or sealing features. This makes them ideal for applications like handles, wearables, and protective housings.
