FDM 3D Printing
Fused Deposition Modelling (FDM) delivers high-quality prototypes and end-use parts in a wide range of materials with fast quoting.
FDM 3d-printed part
What is FDM 3D Printing?
Fused deposition modelling (FDM) is a versatile 3D printing technology that builds parts layer by layer by extruding heated thermoplastic material through a nozzle. FDM 3D printing is a cost-effective option for producing functional prototypes, manufacturing aids and low-volume end-use parts.
Choose from a range of thermoplastic materials, including PLA, ABS, TPU, PETG and PEI, to meet different mechanical, thermal and performance requirements across a wide range of applications.
Benefits of FDM
  • Fast turnaround for prototypes and parts
  • Versatile material options, including heat- and chemical-resistant, flame-retardant, biocompatible, and high-strength materials.
  • Cost-effective manufacturing for custom parts
Common Applications for FDM 3D Printing
  • Aerospace: Lightweight components, enclosures, housings, and antenna covers
  • Automotive: Assembly tools and prototype parts
  • Consumer Electronics: Custom enclosures and housings
  • Medical: Custom prosthetics and anatomical models
FDM Design Guidelines and Capabilities
Our guidelines for FDM include important design considerations to help improve part precision and reduce overall production time.
   Prototyping FDM   Industrial FDM
Max Part Size Up to 500 mm x 500 mm x 500 mm Up to 406 mm x 355 mm x 406 mm
Dimensional Accuracy 0.5 mm ±0.3 mm
Unsupported/Supported Walls Minimum 0.8 mm Minimum 0.8 mm
Minimum Feature Size 2.0 mm 2.0 mm
Minimum Hole Diameter 2.0 mm 2.0 mm
Layer Height Options 100-300 μm 100-300 μm
Infill Options Light to solid to suit strength requirements Light to solid to suit strength requirements
Note: Low resolution: 300-330 μm; Normal resolution: 200-254 μm; High resolution: 100 μm
FDM Material Options
Protolabs' FDM materials for prototyping are typically selected for their ease of use, speed, and cost-effectiveness, which enable rapid design iterations and validation. Production materials are selected for their durability, mechanical performance, and long-term reliability, which ensures that they meet the requirements of end-use applications.
FDM Materials for Prototyping:
Industrial FDM Materials:
PLA (Polylactic Acid)
Offering an excellent surface finish and easy printability, PLA is a biodegradable material ideal for visual models and consumer products
Data sheet
PETG (Polyethylene Terephthalate Glycol)
Offers a good combination of strength and flexibility, making it food-safe and suitable for mechanical parts
Data sheet
ASA (Acrylonitrile Styrene Acrylate)
Provides UV resistance and durability for outdoor applications
Data sheet
ABS (Acrylonitrile Butadiene Styrene)
Offers excellent impact resistance and strength, making it well suited to durable prototypes and functional parts
Data sheet
TPU (Thermoplastic Polyurethane)
Highly flexible and abrasion-resistant, ideal for creating rubber-like components
Data sheet
Nylon (Markforged Onyx)
Offers superior tensile strength and toughness, ideal for functional prototypes and production parts requiring durability and wear resistance
Data sheet
ULTEM (Stratasys)
ULTEM 9085 and ULTEM 1010: Offer high thermal and chemical resistance, making them well suited to demanding aerospace and automotive applications
ULTEM 9085 Data sheet
ULTEM 1010 Data sheet
ASA (Stratasys)
Combines good mechanical properties with UV stability, making it well suited to robust outdoor and automotive components
Data sheet
ABS (Stratasys)
ABS M30: Provides enhanced strength and stability, suitable for end-use parts needing reliable performance under stress
Data sheet
How Does FDM 3D Printing Work?
Fused deposition modelling (FDM) creates parts by heating and extruding thermoplastic filaments layer by layer, resulting in solid objects with practical functionality.
Unlike resin-based technologies such as stereolithography (SLA), which use liquid photopolymers cured by a UV laser to achieve fine details and smooth finishes, FDM offers the advantages of lower costs and faster production times.
Additionally, although powder-based methods such as selective laser sintering (SLS) fuse material powders into complex shapes without the need for support structures, FDM remains a versatile and economical option for producing durable parts, especially when surface finish is not the primary concern. This makes FDM ideal for functional prototypes and low-volume manufacturing across a range of industries.
FAQs About FDM 3D Printing
What is FDM 3D printing best used for?
FDM 3D printing is well suited to functional prototypes, concept models, manufacturing aids, jigs and fixtures, and low-volume end-use parts. Its range of thermoplastic materials makes it a versatile option for applications where functionality, durability and cost-effectiveness are important.
What materials can be used for FDM 3D printing?
FDM can use a wide range of thermoplastic materials with different mechanical, thermal and performance properties. Available materials include PLA, ABS, ASA, PETG, TPU, nylon and high-performance thermoplastics such as ULTEM, depending on the application and FDM process selected.
Is FDM suitable for functional prototypes?
Yes. FDM is commonly used to manufacture functional prototypes that can be used for fit, form and functional testing. Material selection is important, as different thermoplastics offer different levels of strength, flexibility, heat resistance and chemical resistance.
What is the difference between FDM and SLA 3D printing?
FDM builds parts by extruding thermoplastic material layer by layer, while stereolithography (SLA) uses a light source to cure liquid photopolymer resin. FDM is often selected for functional parts and applications requiring thermoplastic materials, while SLA can be better suited to parts requiring fine details and smooth surface finishes.
What is the difference between FDM and SLS 3D printing?
FDM deposits melted thermoplastic material through a nozzle, whereas selective laser sintering (SLS) uses a laser to fuse powdered polymer material. FDM parts may require support structures for certain geometries, while the surrounding powder in SLS supports the part during printing, allowing complex geometries to be produced without dedicated support structures.
Does FDM 3D printing require support structures?
Some FDM parts require support structures for features such as steep overhangs, bridges and complex geometries. Designing with the FDM process in mind can help minimise the amount of support material required and reduce post-processing.
How accurate is FDM 3D printing?
FDM dimensional accuracy depends on factors including the machine, material, part geometry and build orientation. For specific tolerances and minimum feature sizes, refer to our FDM design guidelines and capabilities.
How can I reduce the cost of FDM 3D printing?
FDM costs can often be reduced by optimising part geometry, selecting an appropriate material and infill, and minimising unnecessary support structures. Designing specifically for the FDM process can also help reduce material use and production time.
Other 3D printing processes
