07/05/2025
3D Printing Materials for Rapid Prototyping
Choosing the right prototyping materials can speed up development, reduce costs, and get your product to market faster.
Rapid prototyping lets you move from CAD to part in just days. But not all prototypes need the same material. Some are built for show. Others need to hold up to real-world testing. Here's how to pick the right 3D printing material for the job.
Considerations for material selection in rapid prototyping
When choosing a material for rapid prototyping, it all comes down to what your prototype needs to do. Is it just for checking fit and form? Or does it need to handle stress, bending, or even high heat? Some prototypes are built for looks, others for performance, and your material choice should match the job.
Form and fit
If you’re checking dimensions, tolerances, or how parts connect, you don’t need a high-end material. What matters is accuracy and speed. These prototypes are often handled, assembled, and maybe passed around the office—but they’re not expected to perform under load.
Good options
  • PA 12 (SLS or MJF): Durable, flexible enough for clips and latches, and doesn’t need support structures.
  • ABS or PLA (FDM): Quick, inexpensive, good enough for basic form testing.
  • SLA resins: Great for parts that need crisp details and a smooth surface.
Functional testing
This is where things get more demanding. If your prototype needs to move, bend, hold weight, or resist wear, choose a material that mimics the real-world conditions your final part will face.
Good options
  • PA 12 Glass‑Filled (SLS/MJF): More rigid and stronger than standard nylon—great for load‑bearing parts.
  • Carbon RPU 70 or EPU 40 (DLS): Tough, production-grade materials ideal for impact or flex testing.
  • 316L Stainless Steel (DMLS): Fully functional metal parts for critical applications.
Surface finish and appearance
If your prototype needs to look the part—not just act the part—surface quality counts. Smooth finishes, fine details, and even transparency can make a big difference, especially for presentation models, ergonomic studies, or anything that needs stakeholder sign-off.
Good options
  • SLA resins: Offer high detail and smooth surface finishes, with options for clear or opaque materials depending on your application.
  • PolyJet: Offers multi-colour, multi-material options with ultra-fine resolution.
Speed and cost
When you're in early-stage iteration mode, fast and cheap is usually the winning combo. These materials are good for rough concepts or design tweaks before you move on to functional tests.
Good options
  • PLA or ABS (FDM): Inexpensive and widely available—perfect for same-day concept validation.
  • PA 12 (MJF): Popular choice for batching multiple parts with consistent strength and fast turnaround.
Examples of 3D printing materials for rapid prototyping
What makes a material good for rapid prototyping? Speed is a major factor—some materials print faster than others due to lower curing times, simpler geometries, or compatibility with high-throughput technologies like MJF or FDM. Thermoplastics like PLA and PA 12 are particularly fast and efficient to print, making them ideal for early-stage iterations.
But speed isn’t everything. Choosing the right prototyping material also depends on what you're trying to learn. Early concepts often call for fast, affordable prints to test basic form and fit. As your design matures, you may need tougher or more precise materials to validate function, aesthetics, or mechanical performance.
The best choice is just the one that supports your next design decision.
Rapid Prototyping Material Quick Guide
Prototype goal
Material
Why it works
Fit check
PA 12 (SLS / MJF), ABS (FDM)
Accurate, durable, and quick to produce
Visual model
Smooth finish, fine detail, optional translucency
Snap-fit assembly
PA 12, PA 12 GF (SLS/MJF)
Strong, flexible, and good for functional features
Heat resistance
Accura 5530 (SLA), Aluminium (DMLS)
Withstands higher temps without warping
Flexible part
EPU 40 (DLS), 3D‑printed silicone (PolyJet)
Mimics rubber—great for wearables or seals
Metal component
Titanium or Stainless Steel (DMLS)
High strength, corrosion resistance
Budget iteration
PLA, ABS (FDM)
Low cost, fast print, ideal for rough concepts
Applications and uses
Prototyping materials aren’t one-size-fits-all. Industries often favour different materials based on typical use cases and part performance requirements.
  • Automotive teams often use PA 12, Carbon RPU 70, or ABS for quick-fit checks, snap-fit features, or under-the-hood housings. These materials are tough enough to test form and function at once.
  • Aerospace applications rely on lightweight, high-performance options like PA 12 GF, titanium, or aluminium for brackets, ducting, and housings that need to withstand demanding conditions.
  • Medical and dental designers use SLA resins, 3D printed silicone, and EPU 40 to create precise anatomical models, surgical tools, and comfortable wearable parts.
  • Consumer product developers often opt for SLA resin, PA 12, or PolyJet to produce visual models, device enclosures, or proof-of-concept units with sleek finishes.
  • Industrial equipment requires durable, repeatable materials that can endure harsh conditions and maintain consistent performance. This often includes high-strength polymers and production-grade metals for use in load-bearing or extreme temperature applications.
How materials help in real-world prototyping
  • ForgTin, a medical device company, used DMLS with 316L Stainless Steel to create a durable and compact tinnitus relief device with fine detail and strength.
  • General Drones used MJF and SLS with PA 12 to rapidly 3D print lightweight, precise, multi-geometry parts for rescue drones that respond to emergencies at sea.
  • Downhole Emerging Technologies, a geothermal energy company, used DMLS with Inconel 718, 316L Stainless Steel, and 17-4 Stainless Steel to quickly produce high-performance equipment that wouldn’t melt or corrode in extremely high temperatures.
Strengths and limitations of prototyping materials
Each material has its upsides—and trade-offs. Here's what to expect:
Material
Technology
Strengths
Limitations
PA 12
SLS / MJF
Durable, accurate, versatile
Grainy surface, limited colour options
SLA resins
SLA
High detail, smooth surface
Brittle, not ideal for mechanical loads
ABS/PLA
FDM
Fast, cheap, accessible
Lower resolution, rougher finish
Carbon RPU 70 / EPU 40
DLS
Production-grade strength or flexibility
Higher cost, longer lead times
PolyJet
Soft, flexible, biocompatible
Limited colour and shape complexity
DMLS
Strong, functional, great for heat
Expensive, requires post-processing
Ready to scale? Selecting materials for production
Prototyping is just the first step. Once your design is validated, you might continue with 3D printing for production—or switch to another manufacturing method. The best approach depends on your part requirements, budget, and volume.
Some 3D printing materials are engineered for durability and end-use performance. Carbon RPU 70 and EPU 40, for example, are strong and flexible enough for real-world applications like consumer products, wearables, and flexible components.
These materials are produced with Carbon DLS, a production-grade 3D printing technology that offers smooth finishes and consistent quality—without the need for tooling. It’s ideal for bridge production: when you need a few thousand parts quickly, with end-use quality, but aren't ready to invest in injection moulding. Carbon DLS delivers the flexibility to iterate, scale, and go to market faster.
Frequently Asked Questions About 3D Printing Materials
Can I prototype and produce with the same material?
Yes, if the material meets your performance and cost needs. Carbon DLS and PA 12 are great for both.
What’s the cheapest material for early-stage prototyping?
FDM materials like PLA or ABS are the most affordable.
Which material has the best surface finish?
SLA resins and PolyJet materials offer the smoothest finishes.
Do I need to consider colour at the prototyping stage?
Not always, unless colour impacts part identification, appearance, or function.
Get a quote
Let’s fast-track your prototype. Upload your CAD model for a free, instant quote.
Working with specialised or non-standard materials? Email our team at [email protected]—we love a challenge.
