Multi-Cavity and Family Injection Moulding
Maximise each shot with multiples of the same or different parts from a single mould
What is Family and Multi-Cavity Moulding?
Family moulding and multi-cavity moulding are techniques used to produce multiple parts from a single mould. Rather than producing a single part with each cycle, multiple parts can be produced with a single shot. Multi-cavity moulding describes a tool with the same cavity designed to produce multiples of the same parts. While family moulding describes a tool with various cavity designs such as a left and right components that mate together.
Definitive Guide to Injection Molding Cover
Definitive Guide to Injection Moulding
This complete reference guide walks you through everything from quoting, design analysis, and shipment to best practices that ensure your model is optimised for moulding.
Family and Multi-Cavity Moulding Capabilities
Our basic guidelines for multi-cavity and family injection moulding include important design considerations to help improve part mouldability, enhance cosmetic appearance, and reduce overall production time.
Tolerances: Typically, Protolabs can maintain a machining tolerance of +/- 0.08 mm with an included resin tolerance that can be greater than but no less than +/- 0.002 mm/mm.
Injection Moulding Materials
  • Nylon 6/6
  • PBT
  • PC
  • PEEK
  • PEI
  • PP Homopolymer
  • PP Impact Copolymer
  • PP Random Copolymer
  • PPS
  • PS (GPPS)
  • Silicone
  • TPC-ET
  • TPE
  • TPU
Surface Finish Options
Finish Description
PM-F0 non-cosmetic, finish to Protolabs' discretion
PM-F1 low-cosmetic, most toolmarks removed
PM-F2 non-cosmetic, EDM permissible
SPI-C1 600 grit stone
PM-T1 SPI-C1 + light bead blast
PM-T2 SPI-C1 + medium bead blast
SPI-B1 600 grit paper
SPI-A2 grade #2 diamond buff
How Does Multi-Cavity or Family Moulding Work?
Multi-cavity moulds enable the production of multiple versions of the same part in a single shot. You can take this process to the next logical step when you include many different parts on the same mould, creating a family mould. If you have ever built a plastic model, you’ve probably worked with parts made in a family mould. The runners between each part are left intact, forcing you to break each part off the whole.
Advantages
  • High Production Volume: Significantly increases the number of parts produced per hour compared to a single-cavity mould
  • Efficiency: Maximises machine utilisation
  • Lower Per-part Cost: While the mould itself is more expensive initially, the cost per individual part drops dramatically due to the increased output rate and reduced cycle time per part
Challenges
  • Mould Complexity and Cost: It costs more to design and build a balanced multi-cavity mould due to the added complexity and time it takes to cut the mould, but you might make up for that with a lower piece-part price
  • Balancing: Ensure that all cavities fill evenly and at the same rate for consistent part quality. Careful runner system design is critical
Applications for Multi-Cavity and Family Moulding
For high-volume fasteners, connectors, sub-assembly components, interior trim sets, and small standard parts
Construction
Commodity items like fittings, fasteners, connectors, and closures
Standardised components used across many units, housings, and internal components for specific devices
Medical Devices
Particularly for disposable items and casings for handheld diagnostic tools or kits
Packaging
Especially beverage, food, cosmetic, and pharmaceutical packaging
Appliances
Housings and components for smaller appliances
Types of Parts Function
Electronic device housings Front/back casings, battery doors, button sets for a specific remote control, phone, or gadget
Buttons and keys Keyboards, control panels, remote controls
Caps and closures Bottle caps, jar lids, flip-tops, spray nozzle components (huge volumes needed)
Connectors Electrical connectors, terminal housings, fibre optic connectors (standardised, high quantity)
Fasteners Plastic clips, rivets, screw anchors, cable ties (commodity, high volume)
Medical disposables and casings Syringe barrels/plungers, pipette tips, test tubes, vial caps, parts for IV sets, sample cups. Two halves of a glucose meter casing, parts for a specific diagnostic test kit (high volume, consistency crucial)
Small ears, bushings, washers Standardised mechanical components
Small pipe fittings Elbows, T-connectors, caps for plumbing/irrigation
