FDM 3D Printing
Fused deposition modeling (FDM) creates quality prototypes and end-use parts in a variety of materials and fast quoting
What is FDM 3D Printing?
FDM is a versatile 3D printing technology that builds parts one layer at a time by extruding heated thermoplastics through a nozzle. Known for its affordability and quality, FDM is ideal for low-volume production of both prototypes and functional parts. Work with materials like PLA, ABS, TPU, PETG, and PEI to cover a wide range of applications.
Benefits of FDM
  • Speedy turnaround for prototypes and parts
  • Versatile material choices: heat and chemical resistant, flame retardant, biocompatible, and high strength materials available
  • Cost-effective manufacturing for custom parts
Common Applications for FDM 3D Printing
  • Aerospace: Lightweight components, enclosures, housing, and antenna covers
  • Automotive: Assembly tools and prototype parts
  • Consumer Electronics: Custom enclosures and housings
  • Medical: Custom prosthetics and anatomical models
FDM Design Guidelines and Capabilities
Our basic guidelines for FDM include important design considerations to help improve part precision and reduce overall production time.
      US Metric
Max Part Size Prototyping FDM Up to 19.68 in. x 19.68 in. x 19.68 in. Up to 500mm x 500mm x 500mm
  Industrial FDM Up to 15.98 in. x 13.97 in. x 15.98 in.     Up to 406mm x 355mm x 406mm
Dimensional Accuracy Prototyping FDM ± 0.5% with a lower limit of ±0.020 in.     0.5mm
  Industrial FDM ± 0.3% with a lower limit of ±0.012 in.     ±0.3mm
Unsupported/Supported Walls   Minimum 0.0315 in.     Minimum 0.8mm
Minimum Feature Size   0.0787 in.     2.0mm
Minimum Hole Diameter   0.0787 in.      2.0mm
Layer Height Options from 100-300 μm
Infill Options Light to solid to suit strength requirements
FDM Material Options
Protolabs FDM materials for prototyping are typically chosen for their ease of use, speed, and cost-effectiveness, focusing on enabling rapid design iterations and validation. Materials for production are selected for their durability, specific mechanical properties, and long-term performance, ensuring they meet standards for end-use applications.
FDM Materials for Prototyping:
Industrial FDM Materials:
PLA (Polylactic Acid)
Known for excellent surface finish and ease of printing, PLA is biodegradable and ideal for visual models and consumer products
PETG (Polyethylene Terephthalate Glycol)
Offers a good combination of strength and flexibility, making it food-safe and suitable for mechanical parts
ASA (Acrylonitrile Styrene Acrylate)
Provides UV resistance and weatherability, perfect for outdoor applications
ABS (Acrylonitrile Butadiene Styrene)
Known for impact resistance and strength, suitable for durable prototypes and functional parts
TPU (Thermoplastic Polyurethane)
Highly flexible and abrasion-resistant, ideal for creating rubber-like components
Nylon (Markforged Onyx)
Offers superior tensile strength and toughness, ideal for functional prototypes and production parts requiring durability and wear resistance
ULTEM (Stratasys)
ULTEM 9085 and ULTEM 1010: Known for high thermal and chemical resistance, suitable for aerospace and automotive applications where high performance is critical
ASA (Stratasys)
Combines good mechanical properties with UV stability, perfect for robust outdoor and automotive components
ABS (Stratasys)
ABS M30 and ABSplus: Provides enhanced strength and stability, suitable for end-use parts needing reliable performance under stress
How Does FDM 3D Printing Work?
Fused Deposition Modeling (FDM) creates parts by heating and extruding thermoplastic filaments layer by layer, resulting in solid objects with practical functionality.
Unlike resin-based technologies such as stereolithography (SLA)—which use liquid photopolymers cured by a UV laser to achieve fine details and smooth finishes—FDM offers the advantage of lower costs and faster production times.
Additionally, although powder-based methods such as selective laser sintering (SLS) fuse material powders into complex shapes without the need for support structures, FDM remains a versatile and economical option for producing durable parts, especially when surface finish is not the primary concern. This makes FDM ideal for functional prototypes and low-volume manufacturing across a range of industries.
