Design Guidelines: CNC Turning
Our basic guidelines for CNC turning include important design considerations to help improve part manufacturability, enhance cosmetic appearance, and reduce overall production time.
Size
Maximum Dimensions
Diameter 3.95 in.
Length 9 in.
Diameter
100.33mm
Length 228.6mm
Minimum Dimensions
Diameter 0.16 in.
Length 0.05 in.
Wall Thickness 0.020 in.
Angle 30°
Diameter 4.07mm
Length 1.27mm
Wall Thickness 0.51mm
Angle 30°
Small features may be allowed, but the diameter in any region should not be less than 0.030 in. (0.76mm). Sharp conical points are allowed; angles should be greater than 30 degrees. Walls thinner than 0.020 in. (0.5mm) typically do not survive the machining process. For specific turning dimensions by material, see maximum part extents for machining.
Typically, Protolabs can maintain a machining tolerance of +/- 0.005 in. (0.13mm).
Live Tooling Capabilities
Our lathe machines contain live tools that allow additional milled features to be added to turned parts including flats, slots, and grooves. We can also add on-axis, axial, and radial holes to turned parts, but only support holes that are either parallel or perpendicular to the axis of revolution, and we cannot accommodate holes at odd angles for hard metals. We can mill off-axis holes on turned parts machined from aluminum or brass.
CNC Machining Surface Finish Guide
 Get a realistic snapshot of the surface finishes that are possible on machined plastic and metal parts.
DOWNLOAD >
Design Essentials for CNC Machining
We've compiled some of our best design tips to help you optimize your part design for CNC machining.
DOWNLOAD >
VIEW MATERIALS >
Anodizing and Chromate Plating
Add these specialized finishes to your order to extend the life and improve the look of your parts.
Anodizing
Reduce corrosion and add an appealing metallic coloring to your aluminum parts. Anodizing helps resist scratching, acts as an electrical insulator, and is one of the most durable finishes available.
Specifications:
  • Type II
  • ROHS compliant
  • Class 1 (clear)
  • Class 2 (black)
Chromate Plating
Protect your parts from corrosion while adding electrical conductivity and the ability to paint your part. Note that steel and iron-based metals require pretreating with zinc before applying chromate.
Specifications:
  • Type I, Non-ROHS (yellow)
  • Type II, ROHS (clear)
  • Class 1A: For maximum protection against corrosion, painted or unpainted
  • Class 3: For maximum protection against corrosion where low electrical resistance is required
Surface Finishes
Parts that are turned typically have a very smooth surface finish. The as-machined surface finish of the cylindrical areas will typically be much smoother using the lathe than the mill, so consider this when selecting the machining method for those parts that qualify for either method. Areas cut with live tooling, such as flats and slots, may have visible tools marks. If desired, the metal parts can be lightly bead blasted leaving a fine matte finish. Hard metals like steel and stainless steel can also have edges broken (deburred) with a light bead blast to remove metal slivers, and sharp or rough areas.
ALUMINUM Edges broken with visible toolmarks, edges broken with light bead blast, or sharp edges with visible toolmarks
ALL OTHER METALS Edges broken with visible toolmarks or edges broken with light bead blast
Threaded Holes
We currently support UNC and UNF threads from #2 up to 0.5 in., and metric threads from M2 to M12. Avoid modeling internal threads on your part design.
View Threaded Holes Guidelines >
Radii
Sharp inside corners on a part will be radiused (rounded) as a natural result of the CNC machining process. Resulting radii will be identified before the part is milled. Turned outside corners will typically include a 0.005 in. chamfer.
Holes and Grooves
We can add on-axis, axial, and radial holes to turned parts, and we support holes that are either parallel or perpendicular to the axis of revolution. Off-axis holes are supported for turned parts machined from aluminum and brass.
Text on Parts
Text is not supported on turned parts at this time.
Minimum hole size:
  • On-axis and axial: 0.04 in. (1mm)
  • Radial: 0.08 in. (2mm), 0.04 in (1mm) for aluminum and brass
Grooves:
  • Minimum OD groove width: 0.047 in. (1.2mm)
  • Minimum OD groove width for aluminum and brass:0.019 in (0.5mm)
  • Maximum OD groove depth: 0.95 in. (24.1mm)—varies with groove width
  • ID grooves are not supported at this time
Get an online quote for your CNC design.
Request More Information
Thanks! We’ve received your message and a member of our team will be in touch with you shortly.
You can find more information about Protolabs here:
Thanks for your interest in Protolabs. Please let us know how we can provide more information on our services. Once we receive your comments, an applications engineer from our team will follow-up as soon as possible.
If you have a 3D CAD model of your part ready, upload it online now to receive an interactive quote with free design for manufacturability feedback within hours.
800
