Multi Jet Fusion part
Multi Jet Fusion (MJF) 3D Printing Service
MJF 3D printing builds quality nylon parts suitable for rapid prototyping and production.
Certification + Compliance
Multi Jet Fusion is an industrial 3D printing process that produces functional nylon prototypes and end-use production parts in as fast as 1 day. Final parts exhibit quality surface finishes, fine feature resolution, and ‬more consistent mechanical properties when compared to processes like selective laser sintering.
Common applications for Multi Jet Fusion are:
  • parts requiring consistent isotropic mechanical properties
  • functional prototypes and end-use parts
  • complex and organic geometries with fine features
Multi Jet Fusion Booklet
This 104-page comprehensive booklet on HP’s Multi Jet Fusion Service, provides must-have insight into best practices and in-depth design guidelines on how to best produce your part using this technology.
Design Guidelines for Multi Jet Fusion
Our basic guidelines for Multi Jet Fusion include important design considerations to help improve part manufacturability, enhance cosmetic appearance, and reduce overall production time. ​
  US Metric
Maximum Part Size 11.1 in. x 14.9 in. x 14.9 in 284mm x 380mm x 380mm
Layer Thickness 0.00315 in. 80 microns
Minimum Feature Size 0.020 in. 0.5mm
Wall Thickness 0.020 in. 0.5mm
Tolerances: For well-designed parts, tolerances of +/- 0.012 in. (0.30mm) plus 0.1% of nominal length for each additional inch can typically be achieved. Note that tolerances may change depending on part geometry.
Warpage: Larger part sizes (>7 in.) and parts with thin features are the most susceptible to warp. We recommend maintaining a uniform thickness of 0.125 in. (3.175mm) to ensure stability.
MJF Material Options
PA 12 Black
PA 12 Black is a high tensile strength nylon. Final parts are dyed black, and they exhibit quality surface finishes and slightly more isotropic mechanical properties when compared to SLS. When more detail is required, PA 12 can achieve smaller minimum feature resolution (0.02 in) as compared to SLS materials (0.03 in). PA 12 Black is the best material option for designs that incorporate living hinges.
Primary Benefits​
  • Near isotropic mechanical properties
  • Economical material choice
PA 12 40% Glass-Filled Black
PA 12 40% Glass-Filled Black is a 40% glass-filled nylon. Final parts are dyed black. The biggest advantage offered by this material is heat deflection at 347°F (measured at 66 psi), ranking 2nd best after PA 12 Mineral-Filled.
Primary Benefits​
  • Heat deflection
Compare MJF Material Properties
Material Color Tensile Strength Tensile Modulus Elongation
PA 12 Black Black 7.1 ksi 276 ksi 8.5%
PA 12 40% Glass-Filled Black Black 4.35 ksi 508 ksi 8.5%
PA 12 Black Black 49 Mpa 1,900 Mpa 8.5%
PA 12 40% Glass-Filled Black Black 30 Mpa 3,500 Mpa 8.5%
Multi Jet Fusion Surface Finish
Standard  A bead blast removes all powder and leaves a consistent overall texture. Parts are then dyed a standard black color.
Vapor Smoothing  Significant reduction of surface roughness from 250+ μin RA (as-printed) to 64 – 100 μin RA after smoothing. Available for PA12 Black.
Custom Secondary options include a primer that can be applied as well as taps and inserts.
black mjf 3d printing part with threaded insert
Our MJF 3D Printers
We use HP Jet Fusion 3D 4210 and 5210 machines that are capable of accelerated build speeds when compared to other powder-based additive manufacturing technology. The HP 3D printers produce commercial-grade parts with enhanced surface finishes and improved mechanical properties compared to other 3D printing technology.
HP multi jet fusion logo
How Does Multi Jet Fusion Work?
Multi Jet Fusion uses an inkjet array to selectively apply fusing and detailing agents across a bed of nylon powder, which are then fused by heating elements into a solid layer. After each layer, powder is distributed on top of the bed and the process repeats until the part is complete.
When the build finishes, the entire powder bed with the encapsulated parts is moved to a processing station where a majority of the loose powder is removed by an integrated vacuum. Parts are then bead blasted to remove any of the remaining residual powder before ultimately reaching the finishing department where they are dyed black to improve cosmetic appearance.
Get an instant quote on your 3D printing design.
Upload A Part
